CA hinges were used on everything; and properly installed, I have never had one fail. Some of the pre-cut slots were covered with covering but it was not a problem to find them as the manual gave exact measurements to where they were located! After cuttin
Servo openings cut open. There was not a pulling string in place, but none was needed due to large lightning holes.
Servo installed with a 6" extension. I made sure to use locktite on the threaded rod & nuts after I got the servo setup properly. I used the 1" aluminum arms that came with the Hitec servos and had the recommended throw on the ailerons with them.
There were 2 carbon locating dowels for each panel; here I have already roughed them up with 80 grit sandpaper prior to test fitting. I tested each dowel to ensure it reached to the next rib prior to gluing in place.
