The labeled packages were a real plus. I've never seen an ARF do that before, it was most appreciated!
CA hinges were used on everything; and properly installed, I have never had one fail. Some of the pre-cut slots were covered with covering but it was not a problem to find them as the manual gave exact measurements to where they were located! After cuttin
Hinges installed, using pins to ensure they remain centered while curing.
Servo installed with a 6" extension. I made sure to use locktite on the threaded rod & nuts after I got the servo setup properly. I used the 1" aluminum arms that came with the Hitec servos and had the recommended throw on the ailerons with them.
