The instructions called for removing this foam in a later step, but it was in the way early, so off it went.
Posted by: kepople on Jul 19, 2006 05:47 AM
I used t-pins through the pre drill holes for alignment while gluing up the firewall pieces.
I used Epoxy for this step.
The motor mount/firewall with the reverse mount fit into a notch molded into the fuselage.
Longerons were easier to install with the foam removed
