I used t-pins through the pre drill holes for alignment while gluing up the firewall pieces.
Posted by: kepople on Jul 19, 2006 05:47 AM
When I cut out the belly pan, I had to keep the foam cut out -- and from later steps too! -- as some is reused.
The reverse mount instructions and the front mount instructions are different. The front plate glues to the front nose ring of the airplane.
I used Epoxy for this step.
The instructions called for removing this foam in a later step, but it was in the way early, so off it went.
