I began by installing the servo mounting plates on the wing. No servo extensions were required, which was nice, but fishing the wires through the wing proved a little challenging.
Posted by: kepople on Jul 19, 2006 05:47 AM
Diagrams are in the back of the book. Copies or access to the website mentioned in the text would simply things significantly.
The foam is a real pleasure to work- very solid, and does not tear.
Next I cut the slots in the wing hinge line. This step freed up the surfaces dramatically after a little flexing back and forth. No gluing hinges is a very cool idea!
Setting the wing/stab alignment required no sanding! What a rare treat! Everything aligned eggs-act-lee as it should have, no coaxing or sanding required. I used foam-safe CA rather than epoxy to attach the wing.
