Here is the heat sensor taped to the motor battery.
RPM sensor was glued to a dowel that was glued into a hole drilled in the firewall.
Here is the heat sensor taped to the ESC/speed controller.
Here is the heat sensor taped to the Astroflight motor to take readings.
Here is the FDR installed and connected in my Brummi.
