RPM sensor was glued to a dowel that was glued into a hole drilled in the firewall.
Because of a magnetic source in or around the ball-bearings I used cardboard to help keep the magnet from going there while the glue dried.
Here are the two magnets glued opposite each other. Time to mount the sensor.
Here is the heat sensor taped to the ESC/speed controller.
Here is the heat sensor taped to the motor battery.
