Here are the two magnets glued opposite each other. Time to mount the sensor.
The servo still works in the Y harness even with the FDR unit removed.
Because of a magnetic source in or around the ball-bearings I used cardboard to help keep the magnet from going there while the glue dried.
RPM sensor was glued to a dowel that was glued into a hole drilled in the firewall.
Here is the heat sensor taped to the ESC/speed controller.
