Because of a magnetic source in or around the ball-bearings I used cardboard to help keep the magnet from going there while the glue dried.
One servo connected to receiver and FDR with Y harness.
The servo still works in the Y harness even with the FDR unit removed.
Here are the two magnets glued opposite each other. Time to mount the sensor.
RPM sensor was glued to a dowel that was glued into a hole drilled in the firewall.
