The two wing halves come together in a special central rib that makes assembly quick and easy.
Exterior sensor for the (AFS) system as seen from the bottom on the fuselage.
AFS sensor and receiver/control unit combination.
The tail feathers just bolt in place and the control rods are a snap to connect.
The motor comes preinstalled in the fuselage. That's good because the needle valve is installed right over one of the mounting bolts with the IsoSmooth system. (Bolt not fully installed for this picture, more on that later.)
