All wires now installed correctly and Vs bent to get the ailerons to neutral.
Clear fasteners are used to secure the wing to the struts. This is the top wing; slide it in and secure to struts with these fasteners.
Look at the wires from bell cranks. Wire on right is correctly connected, wire on the left is not, note angle.
Crosspiece connects split elevators and it is connected to the servo back under the wing.
Elevator control rod in center of fuselage runs from servo under wing out to the canard.
