Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis > ESKY Cool & King Tail vibes solutions..... > Post 5005618
Carbon tube, 3mm OD, 2mm ID. 1.98?mm OD alu-titan tips (from old damaged/broken Metal torque shaft). Select hollow carbon tubes with CENTRED holes!
Posted by: MicroHeli-Nut on Feb 07, 2006 10:21 AM
Blade/CP 2 frame and new King Frame
Belt drive pulley and Main Gear
CA. Use 1.5mm-2.0mm drill bit to widen carbon entry if necessary. A bit of sanding may be required.
RE-Fit with 3mm ID bearings
