I spliced in a ton of connectors two 4mm stantdard servo connectors and two JST.
Posted by: quitcherbitchen on Jan 28, 2013 02:38 PM
Made to look like a bomb
All wired up with removable connectors JST and that one in between the 2S battery and the Remote Receiver Switch is the negative tap for the main battery in the Propulsion 3s battery.
Close up of all the wiring. Save about 12 grams over the old set up with a servo and momentary switch only because I had to add a UBEC and more extension wires to the ESC. If I could get rid of the battery for the Sound Unit I could save a lot more weight
