Added the faux-landing gear at the rear. I cut a single wheel in half, sanded both halves flat and glued them on. Looks the part...
Posted by: byxnplanes on Oct 09, 2012 04:26 PM
Target scheme. I've got some Canadian roundels for her.
Glassed the hull. Super light glass cloth and WBPU. A little sanding of the edges. I might put a couple more coats on toward the front for extra strength.
Gorilla glue used to reinforce the wing-screw plate. I want to make this a removable wing for easier transportation.
I shaved down the nose turret a bit more to make it a little lower profile. I thought it looked a bit bulky. Also blended the edges a bit with filler and sanding.
