Target scheme. I've got some Canadian roundels for her.
Posted by: byxnplanes on Oct 02, 2012 09:32 AM
New nose with box features made of depron, a crest shaped wood plate at the front and a random piece of thermoplastic packaging for the turret.
I cut out the painted-on, foam windows and glued small plastic sheets along the exterior of the new window frames. Some pin-stripe added to make them look like separate windows again.
Glassed the hull. Super light glass cloth and WBPU. A little sanding of the edges. I might put a couple more coats on toward the front for extra strength.
Added the faux-landing gear at the rear. I cut a single wheel in half, sanded both halves flat and glued them on. Looks the part...
