Cutting into the wing root to fit a hard blocks through which the wing fixing bolts will pass through, there are four of these in total
Posted by: FWAL on Aug 23, 2012 03:33 AM
The Vee tail is then joined together and I reinforced the joint with GRP
Whilst using GRP I also took the opportunity to strengthen the inner nose
Looking down the fuse, I have shaped a ply plate into which the wing bolt nuts have been installed
Due to the wing profile I had to use a slim wing servo so I chose Hobbyking, they appear to work fine on the bench!
