The Vee tail is then joined together and I reinforced the joint with GRP
Posted by: FWAL on Aug 23, 2012 03:30 AM
The first job was to seal the end of the wing joiner and then glue into place, the wing roots had to be re cut to form the required dihedral
Whilst using GRP I also took the opportunity to strengthen the inner nose
Cutting into the wing root to fit a hard blocks through which the wing fixing bolts will pass through, there are four of these in total
