This particular battery shouldn't have made it through QA. The notch in the mylar wrap is supposed to be on the end with the main power wires. First one I've seen like this!
Posted by: target on Jul 04, 2012 03:54 PM
I start by removing the stickers, and applying them to a piece of clean mylar for saving them to be re-applied. Carefully cut and peel back the shrink tube.
Then slide off the clear plastic sleeve.
Peel off the blue tape and save next to the Hyperion label on the mylar.
Find the end of the mylar, and peel it open, exposing the wire end of the pack. Just tuck it out of the way for now.I use a clamp to gently hold the battery on my bench.
