1/8 piano wire grinded to a point. This is only to mark the center panel. I use blunt pins for normal operation.
Posted by: heliwill10 on Jan 10, 2012 09:50 AM
This is plumbers emery, found in the home stores plumbing section. This will polish up the surface.
Repeat many times untill the fit is what you want. I don't like a fight so mine are pretty loose.
I drill alignment pins towards the TE, here I'm using a nail to make a mark so the drill does not wander.
Here is the mark.
