A healthy bead of thick CA is run down the spar groove before the spar is installed.
Posted by: ChrisBowker on May 19, 2011 09:31 AM
the first step is installing the Wing spar, theres a pre-cut spar groove for the .8x3.2mm flat spar. It may need to be opened up just a touch to allow the spar to sit flush with the bottom of the wing.
The spar is cut to size and ready to be installed. Please note I'm using a sheet of plastic as glue barrier to keep from gluing my model to the work bench.
After installing the spar I use a straight edge from Leading edge(LE) to trailing edge(TE) as shown to hold the wing flat as I put a drop of kicker every 3-5"
Rinse and repeat for the elevator spar.
