Painted parts ready for construction.
Posted by: ChrisBowker on May 19, 2011 09:31 AM
the first step is installing the Wing spar, theres a pre-cut spar groove for the .8x3.2mm flat spar. It may need to be opened up just a touch to allow the spar to sit flush with the bottom of the wing.
The spar is cut to size and ready to be installed. Please note I'm using a sheet of plastic as glue barrier to keep from gluing my model to the work bench.
