The booster can be rotated up to allow access to the binding button.
Posted by: Crist Rigotti on Mar 03, 2011 10:54 PM
Front view showing the coax routing.
Back view showing the general layout of things. I tried to keep everything in the middle so nothing interferes with my hands.
Side view of the booster rotated up. When flying It is rotated down till the lower SMA fitting rests on the back of the transmitter case.
I'm using a SunSky Fox 800mw 1280 MHz video system with a homemade invetered vee antenna with the antenna elements cut to 2 3/16 (55.56mm).
