I made this CF floor plate to spread the stress riser out.
Posted by: winchdoc on May 29, 2010 06:10 PM
First, I patched the inside with CF-Kevlar hybrid material, using the baloon trick to press it against the inside of the fuse.
The outside will get sanded out and patched eventually
Slip it inside with a generous amount of spooge on the edges...
and press it downinto the bottom of the fuse. It forms a closed-in D section on the belly.
