This is the top of the same wing. This spar system takes 6 spars in the "A" shaped spar pattern. DO IT!!!! You'll love it.
Posted by: Lee on Mar 04, 2010 05:37 AM
This spar system is supported by a shock cord, spars, and extreme tape on leading edge, over every spar and top, on elevons and bottom crossed on the motor mount and then a layer of 3mil laminate.
This is the only system I recommend. I built the spars this way for years then got too confident in the strength of flat carbon that wasn't as stiff and strong as I had supposed.
