I wasn't too impressed with the supplied radio, so I resorted to my trusty Spektrum system, and the results were significantly better. Therefore, the F-16 now is not nearly as twitchy as it used to be with its former "Famous" sytem.
Posted by: Spackles94 on Apr 15, 2009 09:51 PM
In the air, there's no discussion about it: It looks good. And, behind the sticks, there's little doubt, either: It flies well.
Flying inverted can prove to be a bit tricky, and it's something that needs to be done with plenty of power or else the plane will nose down in short order.
Into the wild blue yonder. For a foam plane, it performs fantastically.
Here come the F-16s! Here come the F-16s! Sure, it doesn't have any bombs attached to it, but it still can instill some fear in you.
