Flying inverted can prove to be a bit tricky, and it's something that needs to be done with plenty of power or else the plane will nose down in short order.
Posted by: Spackles94 on Apr 15, 2009 09:51 PM
You can zoom along or you can cruise along, and five to seven minutes of flight time certainly are certainly possible with the included 1300mAh pack.
In the air, there's no discussion about it: It looks good. And, behind the sticks, there's little doubt, either: It flies well.
I wasn't too impressed with the supplied radio, so I resorted to my trusty Spektrum system, and the results were significantly better. Therefore, the F-16 now is not nearly as twitchy as it used to be with its former "Famous" sytem.
Into the wild blue yonder. For a foam plane, it performs fantastically.
