High-speed passes low to the ground is what this F-16 excels at. And, if you're using your own radio and dial plenty of expo for it, they're going to be easy to control and will be straight as an arrow.
Posted by: Spackles94 on Apr 15, 2009 09:51 PM
Tinted canopy, sharp nose and sleek curves. It looks intimidating all right. But how will it fly? Let's find out.
Landing is a surprisingly easy feat, and you'll be surprised at the long glide path. It's a floater for sure.
Say, you want some climb power? Well, you've got plenty and then some. The climb rate is good, and it will allow you to perform a (not-so) clean loop with plenty of wattage to spare.
You can zoom along or you can cruise along, and five to seven minutes of flight time certainly are certainly possible with the included 1300mAh pack.
