A standard Aquacraft surface transmitter is included
Posted by: Allan Wright on Aug 26, 2008 05:19 PM
12vDC Peak charger and 7.2 volt 1100 mAh NiMh battery
The stern contains all the essentials: Prop, cooling water pick-up tube and twin rudders for responsive steering
Close up of the transmitter showing rudder trim, crystal, power LED and on-off switch.
The plastic antenna tube is a tight fit in the rubber mount. See text for an easy way to install it.
