Posted by: kgfly on May 15, 2008 08:03 AM
This is how the charger would be connected to the foam cutter bow. Note, that the foam cutting menu should allow the use of an external switch.
USB to 5V serial adapter. Use a servo extension lead to connect to the device to be programmed.
update info.pdf
update info.pdf
