End of the Equal mode and boosting charge again to bring them up to the proper Voltage
Posted by: Smyk on Apr 14, 2008 09:33 PM
Zoomed in charging LI-Ion pattern wit balancing. First 3 with FAST balancing. Following 3 cycles use EQUAL mode
charging fresh (not balanced) pack of 12S A123 with FAST balancing. There was no need to hold this balancing for 20 minutes.Changing to EQUAL mode brought them close in minutes
here is a close up end of the charging process of already healty (prebalanced) 12s A123 pack You can notice the lower cells being up charged while top ones stepping down
here is a sample of 4s3p high resistance cells being charged. Pulses are from charger The little interaptions on the top to the charger patter are from a balancer
