The Axi Gold motor provided for this review is light yet powerful and runs quite efficiently, too.
Posted by: Spackles94 on Feb 23, 2008 11:27 PM
When cutting through the wing in preparation for the rope-and-CA reinforcing, it helps to have drawn a line beforehand. Using a metal ruler is a must.
After a bit of gentle foam removing, the servo pockets are finished. Be sure to test-fit your servos in the process or you just might just end up with an oversized hole.
Don't let this happen to your LiPo, and if it does be sure to take it to get it recycled as soon as possible.
It only takes a few drops of CA glue to attach the motor mount. Be sure to have it centered before you spray it with kicker, and depending on your motor, you might have to remove some foam so the shaft can spin freely.
