The kit also has a pre-cut servo tray made for DS3421 JR servos.
Posted by: target on Oct 03, 2007 02:18 PM
The plane comes with almost everything you'll need to assemble it. The wire extensions are even included for the fuse and wing!
You'll get 4 of these VERY COOL servo frames/output arm bearings. Awesome idea to support the output shaft!
10 ballast slugs, 1.300 KG total, or 46 oz!
Here is the battery I'll use: 4 x CP1300 Sub-C NiCads. Able to fast charge if need be, and should have no voltage drop under load.
