4in span Spitfire 1.2g Durobatics foam. Acrylic paint. Tissue decals. Balsa spinner. 2 channel rud/throttle receiver IRXA261 Tanaka motor Shicoh 3.2mm DD prop 1.1 x.7in (25x16mm) basswood actuator coil 1.6mmID 154ohm magnet 1 x.5mm N50 batt
Posted by: rguillot on Nov 25, 2006 11:02 AM
magnet 1 x.5mm N50
batt
.715g carbon plane .006-.010in carbon rod construction. Polymicro covering wing span 3.9in (100mm) chord 1.5in (38mm) wingloading .68oz/sq ft receiver IRXA261 Tanaka motor Shicoh 3.2mm rebuilt prop 1.1 x.75in (28x19mm) actuator coil 1.6mmID 1
Bumpette 3.1g Durobatics foam construction. Acrylic paint. Epilot's BUMP design 2 channel rud/throttle wing span 6in (128mm) Plantraco .38g Rx, 30mAh Lipo motor 4mm DD (MKO4-10) prop 1.3 x .85in (34x22mm) actuator coil 2mmID 125ohm mag
Little P-Nut 3.5g balsa/Selitac construction. Balsa painted with acrylic. Dave Robelen design, reduced 50%. 3 channel R/E/T wingspan 6.5in (138mm) Plantraco 3ch .38g Rx 30mAh Lipo Prop 2.75 x1.8in (70x45mm) motor 4mm MK04-10 gearing Didel
Frog Models Redwing 3.6g Durobatics foam and balsa construction. Covered with printed tissue. Balsa wheels. 2 ch, rudder/throttle wing span 7in (152mm) receiver IRXA261, 30mAh Lipo motor 4mm (MKO4-10) gearing Didel 12/40 2mod prop 2.4 x1.55
