1/72 scale Mustang P-51D 3.2g Durobatics foam construction. Floquil acrylic paint. Decals from plastic kit. 3 ch, rudder/elev/throttle wing span 6.25in (132mm) Plantraco .38g Rx, 30mAh Lipo motor 4mm DD (MKO4-10) prop 1.3 x.9in (28x20mm) bass
Posted by: rguillot on Nov 25, 2006 11:02 AM
1/72 scale Spitfire 2.95g Durobatics foam construction. Acrylic paint. Printed tissue decals applied with glue stick. Balsa spinner. 2 ch, rudder/throttle wing span 6.25in (132mm) Plantraco .38g Rx, 30mAh Lipo motor 4mm DD (MKO4-10) prop 1.2
1/72 scale Aichi Val 3.8g Durobatics foam and balsa construction. Floquil acrylic paint. Decals from plastic kit. 2 ch, rudder/throttle wing span 7.5in (163mm) Plantraco .38g Rx, 30mAh Lipo motor 4mm (MKO4-10) gearing Didel 9/40 2mod prop 2
.715g carbon plane .006-.010in carbon rod construction. Polymicro covering wing span 3.9in (100mm) chord 1.5in (38mm) wingloading .68oz/sq ft receiver IRXA261 Tanaka motor Shicoh 3.2mm rebuilt prop 1.1 x.75in (28x19mm) actuator coil 1.6mmID 1
